http://mpc-hc.sourceforge.net/
Sorki MPC :)
A tu jest K-Lite codec pack który zawiera MPC i wiele innych fajnych narzędzi.
http://www.codecguide.com/download_kl.htm
Jak przenieść video z VirtualDub do iMovie
No to mam takie dane pliku:
Video: MPEG4 Video (H264) 1280x720 50fps [MPEG4 Video (H264)]
Audio: PCM 48000Hz stereo 1536kbps [Output 2]
General
Complete name : D:\FPV_nagrania\MVI_2354.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 1.62 GiB
Duration : 4mn 59s
Overall bit rate : 46.5 Mbps
Encoded date : UTC 2012-06-17 08:14:17
Tagged date : UTC 2012-06-17 08:14:17
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Baseline@L5.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=12
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 4mn 59s
Bit rate : 44.9 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 50.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.975
Stream size : 1.56 GiB (97%)
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Duration : 4mn 59s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 54.8 MiB (3%)
Language : English
Jaki taki wyeksportować z VD?
General
Format : MPEG-4
Codec ID : qt
Duration : 4mn 59s
Video
Format : AVC
Codec ID : avc1
Duration : 4mn 59s
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Language : English
Audio
Format : PCM
Codec ID : sowt
Duration : 4mn 59s
Bit depth : 16 bits
Language : English
Rozumiem, że to oryginał.
Wklej jeszcze AVI który odtwarza się na iMove.
Jeśli zainstalujesz k-lite to będziesz miał też takie graficzne narzędzie do podglądania kodeków.... oprócz tego w zestawie jest narzędzie sprawdzające i porządkujące kodeki w M$, bardzo pomocne bo potrafi się zrobić bałagan.
Pamiętaj - Każdy dobry uczynek będzie słusznie ukarany :)
Bardzo fajny programik (bawiłem się wersją na MacOS), wyniki konwersji (materiał źródłowy z VD) akceptowalne przez iMovieKarol pisze:Handbrake jest darmowy i konwertuje wszystko na japco :)
http://handbrake.fr/
Tak.paku pisze:Rozumiem, że to oryginał.
Poniżej właściwości dwóch innych prze-konwertowanych (różnymi programami) i akceptowalnych przez iMovie:
Audio: AAC 48000Hz stereo 122kbps [MPEG-4 Audio]
General
Complete name : F:\MVI_2354_X264_convertet.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 8.67 MiB
Duration : 4s 203ms
Overall bit rate mode : Variable
Overall bit rate : 17.3 Mbps
Encoded date : UTC 2012-06-21 19:53:54
Tagged date : UTC 2012-06-21 19:54:00
Writing application : HandBrake 0.9.6 2012022800
Video
Format : AVC
Format profile : Main@L3.2
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Duration : 4s 200ms
Bit rate mode : Variable
Bit rate : 17.2 Mbps
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.373
Stream size : 8.60 MiB (99%)
Writing library : x264 core 120
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=500 / keyint_min=50 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=15.5 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 4s 203ms
Bit rate : 122 Kbps
Maximum bit rate : 138 Kbps
Compression mode : Lossy
Delay relative to video : -40ms
Stream size : 62.7 KiB (1%)
Video: MPEG4 Video (H264) 1280x720 50fps [VideoHandler - MPEG4 Video (H264)]
Audio: AAC 44100Hz stereo 83kbps [SoundHandler - MPEG-4 Audio]
eneral
Complete name : F:\MVI_2354_H264.mp4
Format : MPEG-4
Codec ID : isom
File size : 4.56 MiB
Duration : 6s 140ms
Overall bit rate : 6 224 Kbps
Encoded date : UTC 2012-06-20 19:17:16
Tagged date : UTC 2012-06-20 19:17:16
Video
Format : AVC
Format profile : Baseline@L3.0
Format settings, GOP : M=1, N=25
Muxing mode : Container profile=Baseline@4.1
Codec ID : avc1
Duration : 6s 140ms
Bit rate : 6 131 Kbps
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.133
Stream size : 4.49 MiB (99%)
Language : English
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 6s 130ms
Bit rate : 83.3 Kbps
Sampling rate : 44.1 KHz
Stream size : 62.3 KiB (1%)
Language : English
J
Chyba się nie do końca zrozumieliśmy, VD eksportuje avi - tylko, pisałeś że jakiś AVI ci się odtwarza w iMove.
Podeślij mi dane właśnie tego pliku (AVI), wszystko wyżej to są MOV lub MP4 - nie da się tego zrobić w VD.
Albo wersja nr2, Deshaker w VD z bardzo dobra jakością (słaba kmpresja) do pliku wyjściowego AVI i to czymkolwiek na format iMOVE z pogorszeniem jakości..
Obawiam się, że pozostaje tylko rozwiązanie nr 2 (podwójne kodowanie). Wszystkie moje pliki, które widzi iMovie są w kontenerze mp4, na sieci też nikomu nie udało się (przynajmniej ja nie znalazłem) zaimportować do iMovie pliku w kontenerze avi - najwyraźniej iMovie i VirtutulaDub to dwa "inne światy"...
Czym proponujesz zakodować w VD aby jakość nie ucierpiała przy zachowaniu rozsądnych rozmiarów pliku wyjściowego.
J
J
kodek x264
w wersji dla VD projekt nazywa sie x264vfw /od video for windows/
i dużo poczytaj o ustawieniach opcji w okienku po lewej na górze :)
http://sourceforge.net/projects/x264vfw/files/
