najnowszy jaki się pojawił to http://www.goodluckbuy.com/hdmi-to-av-converter-hd-hard-decompression-card-for-fpv-photography-telemetry-.htmlaleksandrowicz pisze:A ten http://www.goodluckbuy.com/aerial-fpv-h ... nex7-.html
Hd hard decompression card
for FPV Photography use
Suitable for all kinds of wireless AV transmitter use
Power supply:from the receiver, no need to take additional electric power supply
Specification:
- Signal input: 480p(60Hz)、576P(50Hz)、720p(50Hz/60Hz)、1080i(50Hz/60Hz)、1080p(50Hz/60Hz)
- Signal out put: CVBS(1.0Vpp)、S-Video(Y:1.0Vpp、C:0.3Vpp)
- Output video signal impedance matching: 75Ω
- Accord with HDMI1.2a,compatible HDCP protocol
- Optional choice for output video systems: PAL/NTSC
- Weight: g
- Size: 118*84*28mm
- Working environment: - 25 ℃ ~ 75 ℃
- Working environment humidity: 10%-60%
- Voltage:5V
Contains:
1x Converter
1x HDMI Cable
