potrzebna porada dla zaczynajacego zabawe ;)
papiok
Post autor: papiok »
witam jestem amatorem jesli chodzi o quadcoptery ale mam chec kupic sobie taka zabawke na poczatek, nie mialem nigdy stycznosci z tym ale nie chcial bym zaczac bawic sie jakims typem jak syma tarantula mjx itp bardziej interesowal bym sie modyfikacja itd wiecej zabawy tak mysle prosze o porade czy dobrze mysle :?:
i jeszcze jedno pytanie jesli ten zestaw jaka baterie do tego z jaka ladowarka :idea:
z gory dzieki ;-)
Specification
General
Model ZMR250
Quantity 1 Piece
Material Carbon Fiber
Fasteners: Stainless Steel & Red Metal 8/8
Specification
Size 250mm diagonally, 175mm wide, 130mm long motor-to-motor; about 1/2 the size of a regular quadcopter
Motor Mount M2 12mm - 16mm (Tiger MN1806 2300kv, RCX 1804 2400kv), M3 19mm (Tiger MT2206 2000kv, Sunnysky X2204 2300kv)
Maximum Propeller 5"(Suggest 5030 propeller)
Flight Controller Mount 30.5mm x 30.5mm
Board Camera Mount 32mm x 32mm
Motor
Product Name: 1806 2400KV Mini multi-rotor motors
Manufacturers Number: 1806
KV value: 2400kv
Stator diameter: Φ18
Motor Weight: 18g
Supply voltage: 2-3s
Maximum current: 6.5A
Maximum power: 70W
Dimensions: 25*25*33mm (without cable)
ESC
Dimensions: 40 x 27 x 8mm (without cable)
Weight: 14g (contains the line)
Lithium Battery: 2-3S
BEC Output: 5V2A (linear equation)
Continuous current: 12A
Burst current: 14A
Support frequency: 30-499Hz
Output line: 22 # 6cm
FS-T6 Channels: 6 Channels
Mode:Mode 2 Left Hand Throttle
Model Type: Glider/Heli/Airplane
RF Range: 2.40-2.48GHz
Bandwidth: 500Hz
RF Power: Less than 20dBm
Sensitivity: 1024
Low Voltage Warning: 9V
Power: 12V DC (1.5AA*8)
skopiowane ze strony http://www.geekbuying.com/item/ZMR250-C ... 48304.html
czy to dobra cena :?:
Czas zapier.. . a my jak małe dzieci '-_-'
____________________________
ZMR250, TAROT280;\
Andziak
Re: potrzebna porada dla zaczynajacego zabawe ;)
Post autor: Andziak »
na początek to powitalnia i symulator np FREERIDER
a z quadrocopterow na start to kup taki za 100zł i opanuj odruchy
Pioneer 1400 ( rozbity ), MX-2 rplanes ( utopiony ), DG-1000, Twinstar 2, Sbach 342, u can fly hype,
Ja rozumiem ze sklepy wykorzystuja slabosc klientow do przecen, ale zeby az tak lgac?
Price: USD 163.99
Reg. Price: USD 1296.56 Save: 87%
papiok
no ta przecena to zmylka bo za tyle kasy co oni niby zeszli to bys samolot kupil ;)
ZMR250, TAROT280;\
Biorac pod uwage ze wiecej ofert maja podobnie "przecenionych" jak dla mnie sklep laduje na czarnej liscie...
papiok
a znasz jakis polski z dobrymi cenami sklep gdzie mogl bym zlozyc
ZMR250, TAROT280;\
papiok pisze:a znasz jakis polski z dobrymi cenami sklep gdzie mogl bym zlozyc
http://rc-fpv.pl/viewtopic.php?f=22&t=31316&start=30
papiok
k dzieki pawelsky za pomoc, zakupilem zabawke zobaczymy co dalej z tym bedzie ;) pewnie milion polamanych pior temat do zamkniecia
ZMR250, TAROT280;\
RobUK
Post autor: RobUK »
Brawo papiok, rośnie liczba racerów :)
Klasa 250 to chyba najszybciej rosnąca w ilość klasa na świecie ;)
SYMA X5C, White Sheep 480, Sbach 342, Hyperbipe 800, Spitfire MKIIB, AMBeR III Reborn, DeltaRAY, Tarot TL250A RoboCat 270
RobUK
jarnet86
Post autor: jarnet86 »
Nie ma się co dziwić, bo taki rozmiar jest praktycznie idealny do FPV. Nie za duży i ciężki, a zarazem nie za mały by nie reagować zbyt gwałtownie na niewielkie podmuchy wiatru. A widok z pierwszej osoby to chyba jest to co ludzi najbardziej przyciąga do tej formy rozrywki.
A odnośnie tematu wątku. To ostatnio zastanawiam się czy na początek nie był by dobry model Emax Nighthawk Pro 280. Podstawowa wersja jest w miarę przystępnej cenie no i części zamiennych nie brakuje. Potem można bez problemu przenieść kamerkę, nadajnik, aparaturę i silniczki do jakiegoś bardziej customowego projektu.
