Co Wy na to, przyda się taka funkcja?If possible, it would be nice to be able to to save a search for a specific item and receive an email when a buddy code for that item is posted.
BuddyPrice w HobbyKing
http://www.hobbyking.com/buddy.asp?code ... B88E94CB02
http://www.hobbyking.com/buddy.asp?code ... E95AF5ACC0
http://www.hobbyking.com/buddy.asp?code ... B0CE51AB11
http://www.hobbyking.com/buddy.asp?code ... 337329CBAB
http://www.hobbyking.com/buddy.asp?code ... 2A1BB14501
http://www.hobbyking.com/buddy.asp?code ... DC5A3D55F3
http://www.hobbyking.com/buddy.asp?code ... 9673672475
http://www.hobbyking.com/buddy.asp?code ... 27CC1F26ED
http://www.hobbyking.com/buddy.asp?code ... 7116E76BEE
http://www.hobbyking.com/buddy.asp?code ... 1FAC3D5560
http://www.hobbyking.com/buddy.asp?code ... F1A6D88E64
http://www.hobbyking.com/buddy.asp?code ... 3628A3B7F7
http://www.hobbyking.com/buddy.asp?code ... A7F0386755
http://www.hobbyking.com/buddy.asp?code ... C755201B5C
http://www.hobbyking.com/buddy.asp?code ... 7D5930F545
http://www.hobbyking.com/buddy.asp?code ... 9F3EDBB4C9
http://www.hobbyking.com/buddy.asp?code ... 1838987F6B
http://www.hobbyking.com/buddy.asp?code ... FAEE2CF58C
http://www.hobbyking.com/buddy.asp?code ... 09927994BA
http://www.hobbyking.com/buddy.asp?code ... 14AE0DF4B8
http://www.hobbyking.com/buddy.asp?code ... ED3DB9A8DB
http://www.hobbyking.com/buddy.asp?code ... 56C295F1A9
http://www.hobbyking.com/buddy.asp?code ... D553281D03
http://www.hobbyking.com/buddy.asp?code ... E6B89C1D73
http://www.hobbyking.com/buddy.asp?code ... 90E3DF7475
http://www.hobbyking.com/buddy.asp?code ... 3CEEFC927E
http://www.hobbyking.com/buddy.asp?code ... E6DAC4512A
http://www.hobbyking.com/buddy.asp?code ... 5772EE3732
http://www.hobbyking.com/buddy.asp?code ... 10F6F017FB
http://www.hobbyking.com/buddy.asp?code ... D4C3F18276
Dx6i OSD Zbig II, antena śledząca, Video Goggle HeadPlay.
Myślę, że się przyda, chociaż ja i tak obserwuję ten temat, dobrze jak ktoś i tu wrzuci linka :)Matkas pisze:Dostałem propozycje od pewnego użytkownika:Co Wy na to, przyda się taka funkcja?If possible, it would be nice to be able to to save a search for a specific item and receive an email when a buddy code for that item is posted.
- Marciniasty
wał do silnika 3mm średnica 42mm długość , powinien pasować do emax fc2822
wał 3mm x 42mm - 0,47$
- Wojtass_nt
http://www.hobbyking.com/buddy.asp?code=C960F611-EC6A-48D1-8CA7-36BB7C70352F
FrSky DHT 8ch DIY Telemetry Compatible Transmitter Module
Nanotech 1800 3s za 11,34$
http://www.hobbyking.com/buddy.asp?code ... 73433EF759
Turnigy Plush 18A za 8,73$
http://www.hobbyking.com/buddy.asp?code ... 78AE6E82A5
Śmigłą do koptera 9x5 - 3 lewe, 3 prawe za 2,23$
http://www.hobbyking.com/buddy.asp?code ... 822D7816FA
FrSky Receiver antenna 40 cm
http://www.hobbyking.com/buddy.asp?code=5E3D7926-64F0-433D-9EF9-939556CFB0A7
Price before: $2.45
Price After: $1.86
Jakby ktoś jeszcze pływającymi się interesował
Adjustable stinger drive (Silver)
http://www.hobbyking.com/buddy.asp?code=5A3B382D-FE30-411B-A2A1-05CBBE6D117C
Price before: $12.96
Price After: $10.00
CNC Rudder 75mm With Water Pick Up
http://www.hobbyking.com/buddy.asp?code=6638B5A0-9472-489C-A4B6-425EA9374682
Price before: $15.09
Price After: $11.50
Drive Shaft Housing - Red
http://www.hobbyking.com/buddy.asp?code=85270EB3-C61A-4FC6-9ECC-C8EA150F0DBB
Price before: $4.02
Price After: $3.06
Ostatnio zmieniony poniedziałek 20 cze 2011, 20:51 przez Mieciu, łącznie zmieniany 1 raz.
Multi-Remote Receiver operated on/off Switch
http://www.hobbyking.com/buddy.asp?code=35592ADB-4A3C-479F-98A0-D93C3B15CF43
Price before: $9.94
Price After: $8.66
Nylon Clevis 1.8x27mm (10pcs/set)
http://www.hobbyking.com/buddy.asp?code=EA61D1FE-812A-4996-BDEA-A5326F04E96F
Price before: $0.64
Price After: $0.60
Rhino 1050mAh 3S 11.1v 20C Lipoly Pack
http://www.hobbyking.com/buddy.asp?code=EDBDF6B0-E051-47D9-BD75-74120FF6B05D
Price before: $7.19
Price After: $7.02
Cześć,
możesz je znaleźć na stronie, którą wykonałem: http://hk-buddyprice.com/
bądź na innych stronach takich jak: http://hk.rc-international.info/swarm/
Próbuje zaimplementować nowy szablon i potrzebuje przy tym Waszej opini. Proszę, powiedźcie mi czy ten wygląda lepiej, niż ten poprzedni, i czy jest bardziej `user friendly` Chcę dodać kilka nowych funkcji, a na poprzednim szablonie ciężko coś zmienić
http://hk-buddyprice.com/new/home
Pozdrawiam, Mateusz
Pozdrawiam, Mateusz
Jest niezły ale parę rzeczy jeszcze nie działa, pewnie nie dokończyłeś wszystkiego.Matkas pisze:Cześć,
Pozdrawiam, Mateusz
No i co to za Makita tam się reklamuje? : Chyba nie idziesz w komercję co ?
