Entering CLI Mode, type 'exit' to return, or 'help'
# Building AutoComplete Cache ... Done!
# timer show
###ERROR: NOT IMPLEMENTED YET###
TIMER:
# timer
timer E13 AF1
# pin E13: TIM1 CH3 (AF1)
timer B00 AF2
# pin B00: TIM3 CH3 (AF2)
timer B01 AF2
# pin B01: TIM3 CH4 (AF2)
timer E09 AF1
# pin E09: TIM1 CH1 (AF1)
timer E11 AF1
# pin E11: TIM1 CH2 (AF1)
timer C09 AF3
# pin C09: TIM8 CH4 (AF3)
timer A03 AF2
# pin A03: TIM5 CH4 (AF2)
timer D12 AF2
# pin D12: TIM4 CH1 (AF2)
RESOURCE:
# resource
resource BEEPER 1 D15
resource MOTOR 1 B00
resource MOTOR 2 B01
resource MOTOR 3 E09
resource MOTOR 4 E11
resource MOTOR 5 C09
resource MOTOR 6 A03
resource PPM 1 E13
resource LED_STRIP 1 D12
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 D05
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 A00
resource SERIAL_TX 6 C06
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 D06
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 A01
resource SERIAL_RX 6 C07
resource SERIAL_RX 7 E07
resource I2C_SCL 1 B06
resource I2C_SDA 1 B07
resource LED 1 A02
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 4 E02
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 4 E05
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 4 E06
resource ADC_BATT 1 C03
resource ADC_RSSI 1 C05
resource ADC_CURR 1 C02
resource SDCARD_CS 1 A04
resource SDCARD_DETECT 1 D08
resource OSD_CS 1 B12
resource GYRO_EXTI 1 E01
resource GYRO_CS 1 E04
resource USB_DETECT 1 A08
Owszem, mam tak ustawione i w ports Serial RX (włączone) na UART4 i UART6pawelsky pisze:P.S. Zakladam ze masz caly czas wlaczone PPM RX Input w Configuration i wylaczony Serial RX w Ports
