[SOLVED] Problem baro BMP280 i HobbyWing XRotor F4, BF 3.5.2
lemar
Post autor: lemar »
Barometr na I2C zrobionym z UART3, włączony w CONFIGURATION i nieaktywny (na czarno) w BF.
Nieaktywny na panelu sensorów w BF.
Co robię źle ?
Kod: Zaznacz cały
resource SERIAL_TX 3 NONE
resource SERIAL_RX 3 NONE
resource i2c_scl 2 B10
resource i2c_sda 2 B11
set baro_bustype = I2C
set baro_hardware = BMP280
diff all:
Kod: Zaznacz cały
# diff all
# version
# Betaflight / OMNIBUSF4SD (OBSD) 3.5.2 Oct 16 2018 / 22:09:33 (a5e270fee) MSP API: 1.40
board_name OMNIBUSF4SD
manufacturer_id
mcu_id 005900303336510a31383239
signature
# reset configuration to default settings
defaults nosave
# name
# resources
resource I2C_SCL 2 B10
resource I2C_SDA 2 B11
# mixer
# servo
# servo mix
# feature
feature -RX_PARALLEL_PWM
feature RX_SERIAL
feature GPS
feature TELEMETRY
# beeper
# beacon
# map
map TAER1234
# serial
serial 0 64 115200 57600 0 115200
serial 5 2 115200 57600 0 115200
# led
# color
# mode_color
# aux
# adjrange
# rxrange
# vtx
# rxfail
# master
set mag_hardware = NONE
set serialrx_provider = FPORT
set serialrx_halfduplex = ON
set failsafe_delay = 10
set gps_provider = UBLOX
set osd_warn_core_temp = OFF
set osd_rssi_pos = 2385
set osd_tim_1_pos = 2081
set osd_remaining_time_estimate_pos = 2153
set osd_flymode_pos = 2392
set osd_throttle_pos = 2145
set osd_current_pos = 2421
set osd_mah_drawn_pos = 2403
set osd_gps_speed_pos = 2241
set osd_gps_lon_pos = 2048
set osd_gps_lat_pos = 2065
set osd_gps_sats_pos = 2088
set osd_home_dir_pos = 2102
set osd_home_dist_pos = 2103
set osd_altitude_pos = 2263
set osd_debug_pos = 256
set osd_warnings_pos = 2312
set osd_avg_cell_voltage_pos = 2377
set osd_battery_usage_pos = 2408
set osd_disarmed_pos = 2249
set vcd_video_system = NTSC
# profile
profile 0
# profile
profile 1
# profile
profile 2
# restore original profile selection
profile 0
# rateprofile
rateprofile 0
# rateprofile
rateprofile 1
# rateprofile
rateprofile 2
# rateprofile
rateprofile 3
# rateprofile
rateprofile 4
# rateprofile
rateprofile 5
# restore original rateprofile selection
rateprofile 0
Ostatnio zmieniony piątek 26 paź 2018, 05:19 przez lemar, łącznie zmieniany 1 raz.
Re: Problem z barometrem BMP280 i HobbyWing XRotor F4, BF 3.
lemar pisze:Barometr na I2C zrobionym z UART3, włączony w CONFIGURATION i nieaktywny (na czarno) w BF.
A pullupy masz?
lemar
Post autor: lemar »
Nie, ale kolega sprawdzał i nie pomogło. Nie jestem pewien, czy miał poprawną konfigurację, wiec zrobię to jeszcze sam, ale jemu nie pomogło.
lemar pisze:Nie, ale kolega sprawdzał i nie pomogło. Nie jestem pewien, czy miał poprawną konfigurację, wiec zrobię to jeszcze sam, ale jemu nie pomogło.
Bez pullupow to nie ma w ogole o czym rozmawiac. Wazna jest tez rezystancja tychze.
lemar
Post autor: lemar »
Mam 2K, mogę zrobić równolegle 1K. Będzie OK ?
Schemat powyżej OK ?
Najpierw moze pokaz to baro ktorego uzywasz.
lemar
Post autor: lemar »
https://botland.com.pl/czujniki-cisnien ... i-33v.html
Ustawiony na SPI i BMP280 też nie chodzi.
No to na tej plytce juz masz 10k pullupy. Jakim napieciem go zasilasz?
lemar pisze:Ustawiony na SPI i BMP280 też nie chodzi.
Ej no to jak masz ustawiony na SPI to jak chcesz zeby Ci po I2C gadal. CSB masz do masy zwarte?
lemar
Post autor: lemar »
3,3V
Ustawiony w BETAFLIGHT na I2C, teraz sprawdziłem ustawienie na SPI na wszelki wypadek, ale wracam do I2C.
Niczego względem fabrycznych ustawień nie zwierałem. Podpięte GND, VCC 3V3 i pady SDA -> RX3, SCL -> TX3.
Gdzie jest VDDIO ?
lemar pisze:Ustawiony na I2C, teraz sprawdziłem ustawienie na SPI na wszelki wypadek, ale wracam do I2C.
Pytam o ustawienie interfejsu w barometrze a nie w kontrolerze. Jesli nie zwarles CSB do masy, to masz go ustawionego na I2C.
Jaka wartosc ma baro_i2c_address?
I tak przy okazji - Twoj omnibus nie ma przypadkiem wbudowanego baro?
lemar
Post autor: lemar »
Tak rozumiem to pytanie, na module.
Jeśli dobrze zrozumiałem wiki, to 0x77 (nie ustawiłem w CLI :-( ).
NIE, to Xrotor F4, tylko build jest OMNIBUSF4SD.
lemar pisze:Jeśli dobrze zrozumiałem wiki, to 0x77 (nie ustawiłem w CLI :-( ).
Ty mi nie mow co wyczytales na wiki, tylko co Ci mowi CLI.
Twoj modul ma SDO sciagniete do masy, czyli ma adres skonfigurowany na 0x76.
lemar
Post autor: lemar »
Przestawiłem zatem na 0x76, przełączyłem baro_spi_device = 0 (na wszelki wypadek) i zacząłem ustawiać kolejne wartości do baro_i2c_device (nie wiem z czego wynika ta wartość) - w BF odczyty pojawiły się przy 2.
Teraz urządzenie jest widoczne i działa :-D.
Wielkie dzięki za podpowiedź pawelsky :-).
Zatem właściwa konfiguracja to:
Kod: Zaznacz cały
# get baro
baro_bustype = I2C
Allowed values: NONE, I2C, SPI, SLAVE
Default value: SPI
baro_spi_device = 0
Allowed range: 0 - 5
Default value: 3
baro_i2c_device = 2
Default value: 0
baro_i2c_address = 118
Allowed range: 0 - 119
Default value: 0
Allowed values: AUTO, NONE, BMP085, MS5611, BMP280, LPS, QMP6988
Default value: AUTO
baro_tab_size = 21
Allowed range: 0 - 48
baro_noise_lpf = 600
Allowed range: 0 - 1000
baro_cf_vel = 985
baro_cf_alt = 965
lemar pisze:baro_i2c_device (nie wiem z czego wynika ta wartość)
Numer magistrali I2C ktorej uzywasz do podlaczenia
lemar
Re: [SOLVED] Problem baro BMP280 i HobbyWing XRotor F4, BF 3
Post autor: lemar »
Czy inne sensory (kompas, sonar) na tych samych padach będą się różnić tylko *_i2c_adress i *_hardware ?
