Komunikacja Matek F405 z Arduino po UART
FC oparte na Arduino
IceMAN92q
Post autor: IceMAN92q »
Witam :-) Próbuję wykonać komunikacje pomiędzy Matek F405-CTR, a Arduino. O ile odbieranie danych przebiega bez najmniejszych problemów to wysłanie jakiś informacji, np. danych radia mi nie działa. Poniżej dodaję kod
Kod: Zaznacz cały
#include <SD.h>
#include "protocol.h"
#define INBUF_SIZE 64
#define MSP_SET_RAW_RC        200
#define MSP_SET_RAW_RC_LENGTH 16
static uint8_t inBuf[INBUF_SIZE];
static uint8_t checksum;
static uint8_t commandMW;
static uint8_t offset;
static uint8_t dataSize;
static Protocol p;
int8_t c,n;
double i = 0;
double angX, angY, angH, angH2;
double roll1, pitch1, yaw1, throttle1;
double M1, M2, M3, M4;
void setup()
  Serial2.begin(115200);
  //logger.init();
  Serial.begin(115200);
  pinMode(13, OUTPUT);
void loop() // run over and over
  uint8_t  datad = 0;
  uint8_t  *data = & datad;
  //Serial.print(" Witam ");
  // If you dont need a certain log just comment out the two lines for sending and reading
  p.send_msp( MSP_ATTITUDE  ,data, 0);
  readData();
  p.send_msp(MSP_MOTOR ,data, 0);
  readData();
  p.send_msp( MSP_RC  ,data, 0);
  readData();
  uint8_t rc_bytes[] = {1600,1500,1500,1500,1500,1500,1500,1500};
  send_msp( MSP_SET_RAW_RC , rc_bytes, MSP_SET_RAW_RC_LENGTH);
  Serial.print("Kat x: ");
  Serial.print(angX);
  Serial.print("Kat y: ");
  Serial.print(angY);
  Serial.print("Kat z: ");
  Serial.print(angH);
  Serial.print("\n");
  delayMicroseconds(10000); // 1000 Hz
void readData() {
  delay(1);
  while (Serial2.available()) {
    byte c = Serial2.read();
    //Serial.println(c);
    if (c_state == IDLE) {
      c_state = (c=='$') ? HEADER_START : IDLE;
    else if (c_state == HEADER_START) {
      c_state = (c=='M') ? HEADER_M : IDLE;
    else if (c_state == HEADER_M) {
      c_state = (c=='>') ? HEADER_ARROW : IDLE;
    else if (c_state == HEADER_ARROW) {
      if (c > INBUF_SIZE) {  // now we are expecting the payload size
        c_state = IDLE; }
      else {
        dataSize = c;
        offset = 0;
        checksum = 0;
        checksum ^= c;
        c_state = HEADER_SIZE;
    else if (c_state == HEADER_SIZE) {
      commandMW = c;
      checksum ^= c;
      c_state = HEADER_CMD;
    else if (c_state == HEADER_CMD && offset < dataSize) {
      checksum ^= c;
      inBuf[offset++] = c;
    else if (c_state == HEADER_CMD && offset >= dataSize) {
      if (checksum == c) {
        if (commandMW == MSP_ATTITUDE) {
          XYAngle result = p.evalAtt(inBuf);
          angX = result.angleX;
          angY = result.angleY;
          angH = result.heading;
        if (commandMW == MSP_RAW_IMU) {
          IMUValues result = p.evalIMU(inBuf);
          //logger.logIMU(result);
        if (commandMW == MSP_RC) {
          RCInput result = p.evalRC(inBuf);
          roll1 = result.roll;
          pitch1 = result.pitch;
          yaw1 = result.yaw;
          throttle1 = result.throttle;
        if (commandMW == MSP_MOTOR ) {
          MotorValues result = p.evalMotor(inBuf);
          M1 = result.motor1;
          M2 = result.motor2;
          M3 = result.motor3;
          M4 = result.motor4;
        if (commandMW == MSP_RAW_GPS) {
          GPSValues result = p.evalGPS(inBuf);
          //logger.logGPS(result);
      c_state = IDLE;
Program sprawdzony na Cleanflight, Betaflight i iNav. Wszędzie to samo. Dane z IMU umie pobrać jednak nie jestem w stanie ustawić jakieś wartości na kanale radia.
Zmieniałem jeszcze w programach (Cleanflight, Betaflight, iNav) rubrykę Configuration->Receiver na MSP RX input.
Liczę na wasze pomysły ;-)
Ostatnio zmieniony wtorek 03 lip 2018, 17:26 przez IceMAN92q, łącznie zmieniany 1 raz.
Re: Komunikacja Matek F405 z Arduino po UART
Po pierwsze primo delay zuoooo. Jego uzywanie w loopie powinno byc prawnie zakazane.
Po drugie jakiego Arduino uzywasz? 2560? Teensy?
Po trzecie podaj namiary na biblioteke do MSP ktorej uzywasz.
IceMAN92q
Dzięki za słuszną uwagę, co używać zatem zamiast delay?
Korzystam z Adafruit Feather STM32F205. Da się go programować jak klasyczne Arduino.
Dane wysyłałam wykorzystując funkcję
Kod: Zaznacz cały
// Send a message using the MultiWii serial protocol.
void send_msp(uint8_t opcode, uint8_t * data, uint8_t n_bytes) {
  uint8_t checksum = 0;
  // Send the MSP header and message length
  Serial2.write((byte *)"$M<", 3);
  Serial2.write(n_bytes);
  checksum ^= n_bytes;
  // Send the op-code
  Serial2.write(opcode);
  checksum ^= opcode;
  // Send the data bytes
  for(int i = 0; i < n_bytes; i++) {
    Serial2.write(data[i]);
    checksum ^= data[i];
  // Send the checksum
  Serial2.write(checksum);
(źródło: https://github.com/cstubens/MultiWiiSer ... serial.ino)
Próbowałęm nawet wysłać dane na sztywno zgodnie z wzorcem (http://www.multiwii.com/wiki/index.php? ... l_Protocol)
Kod: Zaznacz cały
  Serial2.write((byte *)"$M>", 3);
  Serial2.write((byte *)"16", 2);
  Serial2.write((byte *)"200", 3);
  Serial2.write((byte *)"1600, 1600, 1600, 1600, 1600, 1600, 1600, 1600", 54);
IceMAN92q pisze:Dzięki za słuszną uwagę, co używać zatem zamiast delay?
https://playground.arduino.cc/Code/AvoidDelay
IceMAN92q pisze:Dane wysyłałam wykorzystując funkcję
Przelacz sie z Serial2 an Serial, podepnij sie do PCta i sprawdz w jakims PuTTY albo czyms podobnym co dokladnie (binarnie) jest wysylane przez send_msp
IceMAN92q pisze:Próbowałęm nawet wysłać dane na sztywno zgodnie z wzorcem (http://www.multiwii.com/wiki/index.php? ... l_Protocol)
Kod: Zaznacz cały
To akurat nie ma prawa dzialac bo wysylasz dane jako string (i do tego z przecinkami i spacjami) a powinienes jako ciag danych binarnych.
