[00294151]========== 2016.10.24 14:37:35. boot(15) ============
[00294280]Packet [C:\P3C_FW_V99.99.9999.bin] detected, card sn [0x0022b4bb].
[00294325]Packet upgrade start...
[00294370]Packet checking...
[00294408]Packet vlink 01.06.0080 <-> 01.05.0070.
[00294485]Done.
[00294525]Version checking[1]...
[00294614][09 00][00] v0.1.0.9 -> v0.1.1.0 need upgrade.
[00294660]Done.
[00296695]Waiting for user confirm...
[00306730]Timeout, start upgrade automatically.
[00306806]Firmware upgrading[1]...
[00306870][09 00] Firmware upgrade start...
[00333274][09 00] Firmware upgrade finish without reboot.
[00363315][09 00] Firmware upgrade finished successfully.
[00363352]Done.
[00363395]Version checking[2]...
[00363450][09 00][05] v0.1.1.0 -> v0.1.1.0
[00363489]Packet upgrade finish successfully.
[00148089]========== 2018.07.06 16:19:46. boot(15) ============
[00148127]Packet [C:\P3C_FW_V99.99.9999.bin] detected, card sn [0x81008553].
[00148167]Packet upgrade start...
[00148205]Packet checking...
[00148248]Packet vlink 01.09.0200 <-> 00.00.0000.
[00148289]Record vlink 01.06.0080 <-> 01.05.0070 (flow = 0).
[00148322]Done.
[00148358]Version checking[1]...
[00148428][03 06][00] v2.4.15.5 -> v2.4.20.50 need upgrade.
[00148478][04 00][00] v1.44.0.0 -> v1.51.0.0 need upgrade.
[00148535][09 00][00] v0.1.1.0 -> v0.1.1.1 need upgrade.
[00148664][11 01][00] v2.0.0.32 -> v2.0.0.33 need upgrade.
[00148700]Done.
[00150747]Waiting for user confirm...
[00160795]Timeout, start upgrade automatically.
[00160867]Firmware upgrading[1]...
[00160910][11 01] Firmware upgrade start...
[00225358][11 01] Firmware upgrade finished successfully.
[00225701][03 06] Firmware upgrade start...
[00646700][03 06] Firmware upgrade finished successfully.
[00646755][09 00] Firmware upgrade start...
[00672705][09 00] Firmware upgrade finish without reboot.
[00702739][09 00] Firmware upgrade finished successfully.
[00702804][04 00] Firmware upgrade start...
[00760537][04 00] Firmware upgrade finished successfully.
[00760579]Done.
[00760612]Version checking[2]...
[00760692][03 06][05] v2.4.20.50 -> v2.4.20.50
[00760737][04 00][05] v1.51.0.0 -> v1.51.0.0
[00760811][09 00][05] v0.1.1.1 -> v0.1.1.1
[00760930][11 01][05] v2.0.0.33 -> v2.0.0.33
[00760974]Packet upgrade finish successfully.
[00000695][01 00] Firmware upgrade finished failed (step = 3, err = 0xffffffff).
[00000688][01 00] Firmware upgrade finished failed (step = 3, err = 0xffffffff).
[00000687][01 00] Firmware upgrade finished failed (step = 3, err = 0xffffffff).
[00000685][01 00] Firmware upgrade finished failed (step = 3, err = 0xffffffff).
Log z DJI Phantom 3 Standard
Panowie, szuakełm na necie, ale nie znalazłem specjalnie nic ciekawego, co mogło by mi jakoś pomoc w odczycie LOGu z DJI P3S. Bardzo bym prosił o pomoc w ustaleniu jakie występują błędy ( z czym są one związane) w Phantomie. Na chwilę obecną Gimbal działa na 2 z 3 osiach i brak obrazu z kamerki (Nie działa os zaraz przy kamerce od pionu kamerki). Poniżej log z pliku P3C_FW_LOG_AB.txt. Na samym dole jest spora lista błędów.
Re: Log z DJI Phantom 3 Standard
A skad wzięłeś firmware "P3C_FW_V99.99.9999.bin"?
Nie wygląda na oficjalną wersję.
Log wygląda podejrzanie; nie jest czasem wyedytowany?
Pokazuje że aktualizował tylko moduły [03 06], [04 00], [09 00] i [11 01]:
Następnie jest sukces, a po sukcesie bład modułu [01 00]:
Moduł m0100 nie był aktualizowany, więc skąd jego błąd?
Kod: Zaznacz cały
Kod: Zaznacz cały
