http://rc-fpv.pl/viewtopic.php?f=51&p=507214#p507214
Inicjatywa moze i fajna, ale juz na pierwszy rzut oka widac ze srednio zgodna z rzeczywistoscia. Dla przykladu w przypadku Polski mamy:
Co kompletnie nie uwzglednia wylaczen ze znanego i lubianego rozporzadzenia. Do tego linki kompletnie przterminowane. Trzeba bedzie zasubmitowac im jakis update. Proponuje opracowac tu jakis kadlubek i pozniej przeslac do GDRD...Article 126 of the 2011 Polish Aviation Act deals specifically with UAVs. Article 126 has not yet been translated into English. According to secondary and unofficial sources, under Article 126, UAVs may operate within Polish airspace. All UAVs must have the same systems and devices allowing for flight, navigation, and communication as those carried by manned aircraft. UAVs that do not possess this equipment can only be flown in zones excluded from generally accessible airspace, while UAVs that do possess this equipment may be freely flown in Polish airspace as long as a flight plan is filed with aviation authorities.
Bazujac na Polsce wniosek niestety jest taki ze informacjom z tej strony ufac nie mozna...
