Dzisiaj jest środa 19 wrz 2018, 12:34
Nowy temat Odpowiedz w temacie  [ Posty: 1 ]
Post: niedziela 15 lut 2015, 09:26
1. Nadajnik nowy FPV ImmersionRC 5.8Ghz 600mW - 289zł
Features.
600mW (28dBm, +/- 1dB) of clean output power
SMA Antenna connector, with supplied 5.8GHz antenna.
Frequencies: 5740, 5760, 5780, 5800, 5820, 5840, 5860MHz
Fully compatible with 2.4GHz R/C radios
On-board quiet switching regulator, powers 5v cameras (including HD versions)
Specs:
Weight: 18 grams
Size: 50 x 23mm
Input voltage range: 7~25v
Camera Power Supply: 300mA / 5v
Video Input: 1Vpp, 75 Ohms
2. Nowy Odbiornik ImmersionRC DUO5800 DIversity V4 32ch 5.8GHz - 579zł
Features:
• 32 Channel support, ImmersionRC/FatShark/Airwave, Boscam, Team Black Sheep, DJI
• Exclusive high quality NexWaveRF receiver technology
• Dual A/V output, for two viewing/recording devices
• Single-button user interface, and remote control from the groundstation
• A/V receiver with diversity antenna inputs
• GS-Link for single-cable connection to a groundstation
• Not affected by 2.4GHz, or UHF R/C radios!
•~1km range with 25mW CE-Legal transmitters
Specs:
Dimensions: L=88mm x W=105mm x H=25mm
Weight: 202g
Sensitivity: better than -90dBm
Frequency, Band 1: 5740, 5760, 5780, 5800, 5820, 5840, 5860MHz
Frequency, Band 2: 5705, 5685, 5665, 5645, 5885, 5905, 5925, 5945MHz
Frequency, Band 3: 5733, 5752, 5771, 5790, 5809, 5828, 5847, 5866MHz
Frequency, Band 4: 5865, 5845, 5825, 5805, 5785, 5765, 5745, 5725MHz
Audio: Stereo, Subcarriers on 6.0, and 6.5MHz
Modulation: FM, Audio and Video
Alarm: Low Battery, Programmable
Power Requirements: 6-13v
Power Consumption: ~300mA
3. FPV Gogle i obudowa i LCD 5'' NaPolskimNiebie - komplet 489zł
Gogle FPV 5" obudowa NaPolskimNiebie
LCD Cyclope Eye 5" HD - 800x480 - bez blue-screen'a NaPolskimNiebie
Założone dosłownie dwa razy na testy
4. Nowa Antena Panelowa ImmersionRC 5.8GHz RHCP 13dBi - 289zł
Connector: SMA compatible with all FatShark/ImmersionRC 5.8GHz products
Polarization: Right-hand circular 5.8GHz ISM Band
Gain: 13dBi
Beam width: 35 degrees (H + V)
F/B ratio: 26dB, VSWR is < 1.5:1 (5740 - 5860MHz).
Impedance: 50 ohms.
5. Nowy Odbiornik FPV Skyzone RC832 5.8G 32CH - 179zł
Features:
• 32 channels: Cover A, B, E bands and F bands
• Two switching buttons for the band and channel
• Two digits display for the band and channel
• Power off memory for last channel and band
• dual Independent video and audio signal outputs
Specs:
Video format supported: NTSC/PAL
Antenna connection: RP-SMA, jack
Power input: 12V
Working current: 200mA max
Antenna impedance: 50Ω
Antenna gain: 2db
Rx sensitivity -90dBm
Video impedance: 75Ω
Video format: NTSC/PAL auto
Dimension: 80x 65 x15mm
Weight: 85g
Frequency range:
FR1 5865,5845,5825,5805,5785,5765,5745,5725
FR2 5733,5752,5771,5790,5809,5828,5847,5866
FR3 5707,5685,5665,5645,5885,5905,5925,5945
FR.4 5740,5760,5780,5800,5820,5840,5860,5880
6. Q450 F450 FY450 Glass Fiber Quadcopter Rama - nowa, w oryginalnym opakowaniu - 89zł
7. Hobbyking SK450 Replacement Arm Set - Red (2pcs/bag) - nowe nogi do sk450 - 29zł za 2 sztuki
8. F330 Glass Fiber Mini Quadcopter nowa rama + komplet zapasowych 4 nóg gratis - 89zł
9. HXT 4mm do 3,5mm bullet ESC kabel power breakout - dwie nowe sztuki - 39zł/sztuka
10. HXT 4mm Parallel Charging równoległe 6 packs 2-6s - używany, ale w idealnym stanie - 49zł
11. LC Common Mode Power Filtr FPV 5.8GHz LPF-01 - 49zł
Revision: Rev3 March 2013
Type: passive common-mode low-pass power ripple filter
Modes: common mode, single mode - jumper selectable
Maximum voltage: 16V DC
Maximum current: ~1.5A
Cutoff frequency at -3dB: 127 Hz (attenuates higher frequencies/noise)
Voltage drop over filter: 180mV at 900mA
Maximum voltage ripple: 120mV
Capacitor: Japanese Polymer Capacitor
Impedance/ESR: 0.012 Ohm at 100kHz/16V
Ripple current: 5000mA rms
Choke: German Common-mode Choke
Series resistance (DC): 0.205 Ohm/path
Wire / trace thickness: twisted 22 AWG / 32 mils
Operating temperature: -40 °C to +105 °C
Dimensions: 37.7 L x 8.8 W x 14.5 H mm
Weight: 8.1 grams
RoHS compliant
Designed and made in Europe
12. Kamera FPV Mini CMOS 520TVL PAL - 99zł
Sensor: 1/3 CMOS
Format: PAL 768 × 576
Horizontal Resolution: 520TVL
Minimum Illumination: 0.008Lux/F1.2
Lens / Field of Vision: 3.6mm F2.0/120°
Dimensions: 17x17x24mm
Input Voltage: DC 5-15V
Connector Type: JR style servo plug
Camera Weight: 12g
Zawsze istnieje mozliwosc negocjacji ceny, prosze napisac na PM lub 501934916. Jestem z Gdyni i mozna odbierac przedmioty osobiscie.
Do cen prosze doliczac koszt wysylki 11zł.
Adnotacja #1: najnowsza
Dodatkowo mam na sprzedaż dwa nowe monitory:
RX-LCD5802 Monitor LCD 7 Black 800x480 32CH bez blue-screen z diversity oraz automatycznym wyszukiwaniem kanałów
Jego zalety:
Współpracuje z nadajnikami takich firm jak: Dji, Fatshark, Boscam, Airwave, Immersionrc itp
Podwójny wbudowany odbiornik z funkcją diversity
Brak niebieskiego ekranu kiedy słabnie sygnał lub całkowicie zanika
Duża rozdzielczość ekranu 800x480
Po zaniku sygnału generowany jest ostatni obraz
Niewielka waga i prosta obsługa
Specjalnye gniazdo do zamocowania na statywie
Duży zakres napięć wejściowych od 7 do 16V / 0,85A
Specyfikacja:
Zasilanie: 7-16V DC (0,85A)
Rozmiar: 7" TFT podświetlenie LED
Wideo format: NTSC M, PAL M, NTSC BG, PAL N, NTSC DK, PAL DK, PAL I, SECAM BG
Rozdzielczość ekranu: 800x480
Podświetlenie: 450cd/m2 (max)
Kontrast: 700;1 (max)
Wejście: AV IN,
Moc pobierana: 7,8W
Wyjście audio: 1W
Temperatura pracy: -10 -65°C
Rozmiar: 178x118x23mm
Masa: 442g
W zestwie:
- Monitor
- Anteny
- Przewody
- Ładowarka (której nie ma oryginalnie w zestawie)
- oryginalny karton
Cena: 649zł do negocjacji
RX-LCD5812 Monitor LCD 7 White 1024x600 32CH bez blue-screen z diversity oraz automatycznym wyszukiwaniem kanałów, HDMI oraz USB (Divx..)
http://www.rc-fans88.com/images/201501/ ... 782427.jpg
http://www.rc-fans88.com/images/201501/ ... 782653.jpg
http://www.rc-fans88.com/images/201501/ ... 782150.jpg
http://www.rc-fans88.com/images/201501/ ... 782395.jpg
W zestwie:
- Monitor
- Anteny
- Przewody
- Ładowarka
- oryginalny karton
Cena 749zł do negocjacji
W hangarze:
2x DemonRC Fury - KISS CompactCTRL CC All-in-One, Frsky XSR, Emax RS2205S 2300kv, Tramp 5.8GHz, Runcam Swift 2
FatShark Dominator v3
Taranis X7
